What could be the problem in a transparent p2p wds link that at a bandwidth test, TCP, both ways shows 5 Mbps Tx / 212 kbps Rx? There’s no noise. The signal strenght varies from -76 to -82.
anyone??
btest is not acurate. use a file transfer.
Ok, the clients` upload is very very bad ![]()
You need to improve your signal so it is in the -64 to -72 range.
Try to change the wireless mini-pci cards at both ends.
