Problem
My Google Home Mini and my Trust Smart Cloud ICS2000 Control Station are not conected with the Google Services en Trust Services.
Situation
I’ve a FritzBox from my Internet Provider (XS4ALL). The FritsBox has al ports open tot he MikroTik and is ExposedHost tot he MikroTik. On the FriotzBox is uPnP Disabled.
Mikrotik
I’ve a working Internet conection. I’ve 4 EoIP tunnels perfect working. My MikroTik is also the DHCP Server, the DNS Server is the server address from the domain controller. On the MikroTik I’ve enabled uPnP.
Enyone know why the Google Home Mini and the ICS2000 Control Station isn’t connect?
I have a couple more questions in order to understand your problem better:
Are both devices actually connected (eg.: do they show up in the registration list of any WiFi-interfaces; is the ethernet-interface running)? Do they have an IP-address assigned for the servers?
Can you use torch to monitor the traffic from the device, where does the traffic flow stop?
Can you share a export of your router-config in order for us to examine it and watch for possible issues with the configuration?
You can use the following command, and may remove any IP-address that could identify you or your network:
/export hide-sensitive
I am also from Drenthe, so have a look in my profile for my contact details if you want on-site support from me
Device (Google Home) conected by a unmanaged Switch by a Unifi AP.
I see the device as active in the Unifi Controller
Also active in de DHCP Scope from the MikroTik
In de DHCP is this device static made with codus DHCP option for Google DNS and not AD DNS Server.
The ICS2000 is with a cable conected on one of the interfaces on the MikroTik directly.
But what interests me the most, what port do you have the ICS2000 connected? It seems it has no IP-address configured that way, traffic wouldn’t flow, because it has no device responding on the other side.
What happens if you remove the GoogleDNS option for the Google Home Mini? Can it connect in that case?
