Thanks god (Normis? ), you removed it! I almost hated it - I can’t disable it between sessions; when I click some link on fresh page, bar opens and moves the page exactly one link down - so wrong page is being loaded…
I don’t know what you solve 2-3 weeks ago, but that ‘page move down’ is still here. I even closed my IE and run Firefox (it was never showing that forum, so nothing to refresh) - when bar appears, page content is moved one link down, if we’re talking about index page. so I click General forum, bar appears, and I go to Beginners one…
I looked into it, and nothing is moving in any of my 5 browsers. The dropdown link simply appears in it’s place, after the page loads. Layout of page doesn’t change when it appears. I tried different browser sizes as well. Hmm.
I just tested it, I have a similar bar showing up after I select a translation language. If you do not translate the page, it doesn’t show up. Also, at least for me, the bar shows up only after I click the dropdown, not by itself.
on your screenshot, you have “Select Language” under The Dude Ad. mine is in Russian, why is your not in Latvian?.. seems like the bar is not appearing because it doesn’t want to translate from English to English
done. refresh a few times, and reload browser.
p.s.: another tip, you don’t seem to be using the bookmark bar. remove it, to have more space on your small screen. also consider F11
what does “layout: google.translate.TranslateElement.InlineLayout.SIMPLE” mean? google’s page generates the script for me without that line… maybe try to remove it? )))
thanks, I’m using FF about twice a year, and I narrowed the window just to make screenshots
