Hello everyone.
I’ll do my best to be as concise as possible.
I have this Mikrotik router: RB2011UiAS-2HnD-IN with GPON Optical Fiber 1Gbps from Digi (RCS & RDS Romania).
I recently bought this SFP module: https://www.batna24.com/en/p/extralink-sfp-125g-sfp-wdm-module-rmnni
Here are the details about the SFP module:
Features / Filters
Output connector: > SC
SFP module - port speed: > 1,25 Gbps
Transmission distance: > 1-3km
Certification: > FCC
Fiber optic connector: > SC
Fiber type: > SM (Single-Mode)
Interface type: > SFP
Maximum data transfer rate: > 1250
Maximum transfer distance: > 3000
Number of products included: > 2
SFP transceiver type: > Fiber optic
Single-mode fiber (SMF) supported: > Yes
Sustainability certificates: > CE, RoHS
Type of SFP duplex: > Wavy (WDM)
Wavelength: > 1310/1550 nm, 1550,
Wavelength-division multiplexing (WDM): > YesBasic Technical Parameters
Data rate: > Double, 1.25 Gbps/1.063 Gbps
Transmission 3 km: > 1310 nm FP laser and PIN photodetector
Compatibility: > Compliant with SFP MSA and SFF-8472 with SC socket
Digital diagnostic monitoring: > Internal or external calibration
Compatibility: > SONNET OC-24-LR-1, RoHS
Power supply: > +3.3 V
Temperature: > 0° to 70°C
Can you help me set it up? What should I take into account? I have a PPPoE fiber connection.
Thank you! ![]()
