GPON - Modem-ID
Hey guys,
I finally got my fiber optic internet connection.
Now I would like to continue using my RB3011 as a router and “modem”.
I bought a GPON transciever from AVM and installed it in the SFP port.
My provider now requires a so-called “modem ID”.
In the case of a Fritzbox, this can be found on the router’s type plate and consists of 12 characters.
How do I find out the modem ID of the RB3011?
It is not the serial number of the GPON SFP.
Thanks.
output of the sfp interface:
[admin@MikroTik] /interface/ethernet> monitor
numbers: SFP-GPON
                    status: no-link
          auto-negotiation: done
               advertising:
  link-partner-advertising:
        sfp-module-present: yes
               sfp-rx-loss: yes
              sfp-tx-fault: no
                  sfp-type: SFP-or-SFP+
        sfp-connector-type: LC
        sfp-link-length-sm: 20km
                    status: no-link
               advertising:
               sfp-rx-loss: yes
              sfp-tx-fault: no
           sfp-vendor-name: ACAL BFi
    sfp-vendor-part-number: FHM5820LA-34AVM2
       sfp-vendor-revision: 1.0
         sfp-vendor-serial: AB22090610878
    sfp-manufacturing-date: 22-09-06
            sfp-wavelength: 1310nm
           sfp-temperature: 38C
        sfp-supply-voltage: 3.389V
       sfp-tx-bias-current: 24mA
              sfp-tx-power: 2.641dBm
           eeprom-checksum: good
                    eeprom: 0000: 03 04 07 00 00 00 02 00  00 00 00 03 0c 00 14 c8  ........ ........
                            0010: 00 00 00 00 41 43 41 4c  20 42 46 69 20 20 20 20  ....ACAL  BFi
                            0020: 20 20 20 20 00 00 00 00  46 48 4d 35 38 32 30 4c      .... FHM5820L
                            0030: 41 2d 33 34 41 56 4d 32  31 2e 30 20 05 1e 00 d0  A-34AVM2 1.0 ....
                            0040: 00 0a 14 14 41 42 32 32  30 39 30 36 31 30 38 37  ....AB22 ********
                            0050: 38 20 20 20 32 32 30 39  30 36 20 20 68 f0 02 1d  8   2209 06  h...
                            0060: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
                            0080: 5f 00 d3 00 5a 00 d8 00  8c a0 75 30 88 b8 79 18  _...Z... ..u0..y.
                            0090: c3 50 05 dc af c8 07 d0  9b 82 22 d0 8a 99 27 10  .P...... .."...'.
                            00a0: 09 d0 00 0c 07 cb 00 0e  ff ff ff ff ff ff ff ff  ........ ........
                            00b0: ff ff ff ff ff ff ff ff  00 00 00 00 00 00 00 00  ........ ........
                            00c0: 00 00 00 00 3f 80 00 00  00 00 00 00 01 00 00 00  ....?... ........
                            00d0: 01 00 00 00 01 00 00 00  01 00 00 00 ff ff ff 26  ........ .......&
                            00e0: 26 3e 84 68 2f b9 47 c2  00 00 ff ff ff ff 02 00  &>.h/.G. ........
                            00f0: 00 40 00 00 00 40 00 00  00 00 07 ff ff ff ff 00  .@...@.. ........
eg. GPON_SN ABCD12345678
You must take serial number from provider (Fritzbox) or make it by yourself. I have Huawei ONT and to have SN must take first half of the number and convert it trough HEX → ASCII, eg. Huawei: 48575443 → HWTC and the second half you must use instead of 12345678
You need an SFP with integrated ONU, not just an SFP transceiver.
by my mikrotik SN i get x= as ASCII :slight_smile:
So i think, i have to use HWTC and then the SN of the SFP.
But i think i found a Solution (but i have not tested yet) here:
http://forum.mikrotik.com/t/how-to-connect-via-ssh-to-gpon-spf-module/161880/1
I have bought a SFP with ONU and MAC, thanks to @nFin1ty fr this information!
