I have RB962UiGS-5HacT2HnT router with GPON SFP module. Connected fiber optic cable and try get connection. But I can’t make work properly.
My question about SFP module temperature. It is normal 85C ?
I try disconnect FC cable but temperature still same.
My GPON module is OK? How can I check? Or is something wrong with him?
I do not have an answer to this question, as the GPON module that I have runs on 93C and does not work (pretty much the same screen as you, apart from the temperature). So, I cannot make it work, and I do not have any idea what might be wrong. Will try to replace the module, maybe that will help. No idea.
