GPS integration problem
Hello all,
I am trying to incorporate a Garmin GPS 15H into a mobile CPE device and I have run into a bit of a problem. When I reboot the CPE with the GPS connected to the serial port the routerboard locks during the boot process. If I disconnect the GPS I can boot normally and if I reconnect the GPS after the CPE is booted then I receive my location info as desired. Anyone have any ideas as to why the boot crashes with the GPS connected?
Thanks,
Jason
disable any key access to the bios, that should fix it I beleive
/system routerboard settings set enter-setup-on=delete-key
Thanks Forepoint, that absolutely did the trick.
Jason
