GPS monitor format change
It appears the output format of the /system gps monitor command has changed in RouterOS v5.5. Strings no longer appear to be wraped with quotes. I can see no mention of this change in the release notes and want to make sure it is an intentional change before I make the relevant scripting changes. Can someone please confirm?
RouterOS v4.17
[admin@MikroTik] /system gps> monitor
date-and-time: nov/30/1999 00:00:00
longitude: “none”
latitude: “none”
altitude: “none”
speed: “none”
valid: no
satellites: 0
RouterOS v5.5
latitude: none
longitude: none
altitude: none
speed: none
valid: no
satellites: 0
The wiki for this page is very light but the old v3 documentation has a bit more detail about the parameters and an example.
http://www.mikrotik.com/testdocs/ros/3.0/system/gps.php
