We have RB411UAHR with 3G card Sierra MC8780 (F1_2_3_15AP firmware) installed. We’d like to use GPS on this card but can’t get raw gps data (NMEA channel).
We discovered that USB2 channel 2 is AT command port but we didn’t find any NMEA port - channel 0 and 1 simple display “CONNECT 7200000” or strange characters like below…
Previously we was testing Option GTM382 and we got nmea gps data on one of the channel…
Should somebody manage to run GPS on this card in Mikrotik ?
When I insert Sierra MC8780 in my old Dell and install 3G Watcher tool COM9 is AT Command port and COM12 is NMEA port and after entering “at!gpstrack=1,60,10,1000,60” on COM9 I get full NMEA data on COM14…
[admin@MikroTik] > port print detail
Flags: I - inactive
0 name="serial0" used-by="Serial Console" channels=1 baud-rate=9600 data-bits=8 parity=none stop-bits=1
flow-control=none
1 name="usb2" used-by="" channels=3 baud-rate=9600 data-bits=8 parity=none stop-bits=1 flow-control=none
[admin@MikroTik] > system serial-terminal usb2 channel=2
[Ctrl-A is the prefix key]
at+gmr
F1_2_3_15AP C:/WS/FW/F1_2_3_15AP/MSM7200R3/SRC/AMSS 2008/07/09 13:02:11
OK
at!gpstrack=?
!GPSTRACK: <fixtype>,<maxtime>,<maxdist>,<fixcount>,<fixrate>
<fixtype>: 1-Standalone, 2-MS-Based, 3-MS-Assisted
<maxtime>: 0-255 seconds
<maxdist>: 0-4294967280 meters
<fixcount>: 1-1000,1000=continuous
<fixrate>: 1-1799,999 seconds
OK
OK
[Q - quit connection] [B - send break]
[A - send Ctrl-A prefix] [R - autoconfigure rate]
Welcome back!
[admin@MikroTik] > system serial-terminal usb2 channel=1
Đ~ Đ~ Đ~ Đ~ Đ~
Welcome back!
[admin@MikroTik] > system serial-terminal usb2 channel=0
CONNECT 7200000
