I am trying to install gps-6.27-mipsbe.npk with WinBOX v.6.27 on a RB953GS-5HnT
I can not drag and drop the package in files list. Also I can not drag and drop any .npk package. It is not allowed. I am doing someone bad?
Could you help me?
I am trying to configure de MC7710 GPS in directip mode.
I have lte1 interface connected and working with internet.
I have ubs2 port GPS, channel 5, 9600.
enabled: yes
port: usb2
channel: 2
init-string:
set-system-time: yes
try to connect to the channel2 using Serial-terminal to check if there is some GPS command output.
You can try to usb-power-reset the modem and check if that brings the output on the GPS channel.
