GPS Problem
Hi all
Has anyone had problems with the GPS before?
When i plug my GPS in, it all works fine… but after some time i just freezes!
And i’m running RouterOS 3.30 also try’d with 4.0 and 4.1 no luck!
This is from my RB411U:
[admin@MikroTik] > /system gps monitor
  date-and-time: oct/19/2009 05:34:18
      longitude: "E 8 xx' 2''"
       latitude: "N 56 xx' 52''"
       altitude: "32.500000m"
          speed: "0.037040 km/h"
          valid: yes
Then i unplug the USB GPS from the board and plug it back in…
Because i can’t disable it and enable it again on the RB411U like i can on the Soekris for some reason?
  date-and-time: oct/20/2009 00:55:56
       latitude: "N 56 xx' 51''"
       altitude: "26.400000m"
          speed: "0.277800 km/h"
          valid: yes
I runs from 1 hour to 20 hours before it freezes again :frowning:
Now this is from a Soekris Board x86:
11/10-2009:
[admin@MikroTik] > /sys gps monitor
  date-and-time: oct/04/2009 20:06:53
       altitude: "37.200001m"
          valid: yes
[admin@MikroTik] > /sys gps set enabled=no
[admin@MikroTik] > /sys gps set enabled=yes
  date-and-time: oct/11/2009 02:23:00
       altitude: "28.500000m"
          speed: "0.185200 km/h"
          valid: yes
12/10-2009:
  date-and-time: oct/11/2009 20:29:17
       altitude: "31.700001m"
          speed: "1.463080 km/h"
          valid: yes
  date-and-time: oct/11/2009 23:33:39
       altitude: "40.500000m"
          speed: "0.444480 km/h"
          valid: yes
[admin@MikroTik] >
14/10-2009:
  date-and-time: oct/12/2009 01:53:40
       altitude: "27.200001m"
          speed: "0.074080 km/h"
          valid: yes
  date-and-time: oct/13/2009 22:20:57
       altitude: "22.100000m"
          valid: yes
[admin@MikroTik] >
17/10-2009:
  date-and-time: oct/14/2009 01:21:19
       altitude: "29.299999m"
          valid: yes
  date-and-time: oct/17/2009 06:00:04
       altitude: "30.700001m"
          speed: "0.148160 km/h"
          valid: yes
17/10-2009:
  date-and-time: oct/17/2009 19:04:25
      longitude: "E 8 xx' 3''"
       altitude: "23.600000m"
          speed: "0.259280 km/h"
          valid: yes
  date-and-time: oct/17/2009 22:53:54
       altitude: "39.200001m"
          speed: "0.240760 km/h"
          valid: yes
18/10-2009:
  date-and-time: oct/18/2009 02:15:45
       altitude: "35.000000m"
          valid: yes
  date-and-time: oct/18/2009 18:14:57
       altitude: "39.900002m"
          valid: yes
The GPS:
[admin@MikroTik] > /system resource usb print
 # DEVICE VENDOR                                NAME                                SPEED
 2 2:7    Prolific Technology Inc.              USB-Serial Controller D             12 Mbps
This is the 2. USB GPS that i’ve try’d with (and they both run with no problem in OSX and Windows for weeks).
Any solutions?
//Ken
make suport.rif before it reeze and when its frozzen and sed to support
why can’t you disable it on RB, what happens?
It say’s that it is in use… but if i remove the cable and plug it back in it says that a background process is using it…
Now what the f?
  MMM      MMM       KKK                          TTTTTTTTTTT      KKK
  MMMM    MMMM       KKK                          TTTTTTTTTTT      KKK
  MMM MMMM MMM  III  KKK  KKK  RRRRRR     OOOOOO      TTT     III  KKK  KKK
  MMM  MM  MMM  III  KKKKK     RRR  RRR  OOO  OOO     TTT     III  KKKKK
  MMM      MMM  III  KKK KKK   RRRRRR    OOO  OOO     TTT     III  KKK KKK
  MMM      MMM  III  KKK  KKK  RRR  RRR   OOOOOO      TTT     III  KKK  KKK
  MikroTik RouterOS 4.1 (c) 1999-2009       http://www.mikrotik.com/
  date-and-time: nov/30/1999 00:00:00
      longitude: "none"
       latitude: "none"
       altitude: "none"
          speed: "none"
          valid: no
[admin@MikroTik] > /system serial-terminal usb2
failure: port's channel is already in use
[admin@MikroTik] > /system gps set enabled=no
[Ctrl-A is the prefix key]
`x` ~ ` xxxx x x xxx fxxx   xx      xxx xx xx x x f x x  x x xx  x     `xx  x       xxxxfxx x  `x` ~     fxxx   xx      x
xx xx xx x x f xxxx x x xxx  ffx`    `x` ~     x xx x x x x x x x x x  xx           x xx x x x `xfx x  `x` ~  f  x x x x
x x fxx xxx x  x  `x x x xx  xx x x `x  xx xx x x x x xx`x xx  ~x    `x` ~  f  x x x x x x xx  xx xx  xx xx x xx  x  xx x
x xxx x x xx  xx  xx   ~x x  `x` ~  f  x x x x xx  xx xx x   x  x  x x    x x xx xx   `x`    `x`     xxxx x x xxx  fxxx
 xx      xxx xx xx x x f x x x ~xx `x  xx xxx x     ffx    `x` x ` ~ ~xx `x  `         x x x     x `x     fx`    `x` ~ `
xxx xxx xxx fxxx   xx      xxx xx xxx f x x  x x xx  x     `xx  x       xxxxfxxx    `x` ~     fxxx   xx      xxx xx xxx f
 xxx xxx xxx  ffx    `x`     xxx xxx xxx  fxxx   xx      xxx xx xxx f x x  xx x x xx xxx x     fxx x  `x` x ` ~ xx x x `
        x x      x x     fx    `x` ~ ` xxx xx x xxx fxxx   xx      xxx xx xx x x f x x  x x xx  x     `xx  x       xxxxfx
x x  `x` ~     fxxx   xx      xxx xx xx x x f xxx xx x xxx  ffx x  `x`     xxx xx x xxx  fxxx   xx      xxx xx xx x x f x
 xx  xxxx fxx xx xxx x     fxx x  `x` x ` ~ xxxx fxx `         x xx      x x     fx    `x` ~ ` xxx xxx  xxx fxxx   xx
  xxx xx xx x x f x x  x x xx  x     `xx  x       xxxxfxx    `x` ~     fxxx   xx      xxx xx xx x x f xxx xxx  xxx  ffxx
   `x`     xxx xxx  xxx  fxxx   xx      xxx xx xx x x f x xx  x x  x x xx xxx x     fxx    `x` x ` ~ x x  x x `         x
 xx      x x     fx x  `x` ~ ` xxx xxx  xxx fxxx   xx      xxx xx xxx f x x  x x xx  x     `xx  x       xxxxfxx x  `x` ~
    fxxx   xx      xxx xx xxx f xxx xxx  xxx  ffx    `x`     xxx xxx  xxx  fxxx   xx      xxx xx xxx f x x x xx x fx  xx
xxx x     ffxx  `x` x ` ~ xx x fx  `         x x x     x x     fx x  `x` ~ ` xxx xx  xxx fxxx   xxx      xxx xx xxx f x x
  x x xx  x     `xx  x       xxxxfxxx    `x` ~     fxxx   xxx      xxx xx xxx f xxx xx  xxx  ffx    `x` ~     x xx x x x
x x x x x x  xx           x xx x x x `xfx x  `x` ~  f  x x x x x x fxx xxx x  x  `x x x xx  x  x x `x  xx x  x x x x xx`x
 xx  ~x    `x` ~  f  x x x x x x xx  xx xx  xx xx x xx  x x xx xx xxx xx xx
[Q - quit connection]      [B - send break]
[A - send Ctrl-A prefix]   [R - autoconfigure rate]
xx  xx   ~x    `x` ~  f  x x x x xx  xx xx x   x  x  x x    x x xx xx   `x`    `x`     xxx xx  xxx  fxxx   xxx      xxx x
x xxx f x x   x   xx xx xxx x     ffxx  `x` x ` ~  x   xx `         x x      x x     fx`    `x` ~ ` xxx xx x xxx fxxx   x
x      xxx xx xx x f x x  x x xx  x     `xx  x       xxxxfxx    `x` ~     fxxx   xx      xxx xx xx x f xxx xx x xxx
Welcome back!
    x xx       x x     x   xx            x    x    x   x   x   x    x  xx xx x    xx  x   x      xx  xx  x      x   xx  x
x     x    x  x x    x      xx            x    x    x   x   x   x    x  xx xx       x x     x   xx xx  x x     x x    x
xx    xx       x x     x   xx xx            x    x    x   x   x   x    x  xx x  xx x  xx   x   x    x   x xxxx  x x     x
 x    x x x   xx   x   xx xxx  x  xx x  x   x  x   x x xx  x       x x    x    x xx       x x     x   xx            x
x  x   x   x   x    x    xx xx x    xx  x   x      x   xx  x      x   xx  xx     x      x x    x      xx            x
x  x   x   x   x    x    xx xx       x x     x   xx xx  x x  x x x    x  xx    xx       x x     x   xx xx            x
 x  x   x   x   x    x    xx x  xx   xx      x      x    x   x xxxx  x    x x x    x x x   xx      x      x
x xxx  x  xx   x   x  x   x x xx  x    x x    x    x xx       x x   x   xx            x     x x   x   x   x    x x  xx xx
 x    xx  x   x      x xx  x      x   xx  xx     x    x x x    x      xx            x     x x   x   x   x    x x  xx xx
     x x   x   xx xx  x x    x x    x  xx    xx       x x   x   xx xx            x     x x   x   x   x    x x  xx x  xx
  x        x   x    x   x xxxx  x      x x    x x x   x        x   xx xxx  x  xx    x   x  x   x x xx  x    x x    x    x
 xx       x x x  x   xx            x        x   x   x   x    x   xx xx x    xx  x   x      xx xx  x      x   xx  xx     x
Welcome back!
[admin@MikroTik] >
The speed was set to 4800bps where it works… but i got the above, then i toke it to 19200bps still the same and back to 4800 now it gives me what i want…
[admin@MikroTik] > /system gps set port=usb2 set-system-time=no enabled=yes
  date-and-time: oct/20/2009 12:33:12
       altitude: "31.299999m"
          speed: "0.777840 km/h"
          valid: yes
Now i just need to see if it wants to crash again, so i can make the supout…
I did upgrade back to 4.1 where i got the funky output from the serial port! did not in 3.30.
Reply from Mikrotik: it will be fixed in 4.2
And it was not fixed! :frowning:
I want to weigh in on the GPS not working using X86 ROS. It is working correctly, when I move the GPS receiver output to a RB433AH so the GPS itself is working. I have installed the GPS pkg in the X86 box, and it seems to configure correctly. I am using ROS 4.2 in both devices.
-tp
Do you also get the data spas’em? when using the “serial-terminal” command?
I’m still waiting for an answer form Mikrotik now 5days after my last report…
can we read the long and lat values via smnp in any way?
with date time and speed?
Now i am promised that it will be fixed in 4.3 :slight_smile:
And it was not fixed… :frowning:
Died after 5hours.
On RB411U:
[admin@MikroTik] > /system gps set port=usb2 set-system-time=yes enabled=no
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
input does not match any value of port
[admin@MikroTik] >
Where did my usb port go?
[admin@MikroTik] > /port print
Flags: I - inactive
 #   NAME                                          CHANNELS   USED-BY                                          BAUD-RATE
[admin@MikroTik] >
[admin@MikroTik] > /log print
jan/01/2002 02:00:02 system,error,critical System rebooted because of kernel failure
please make suput.rif files in the problematic router, at the problematic times, and send to support with description and instructions. we will see what we missed
GPS functionality seems to have been restored in ROS version 4.3 (x86) for me.
Thanks MikroTik :slight_smile:
-tp
From 4.4 on R411U:
Did nothing else but what i did in the terminal…
And why is it, that when i update my RB411U all extra packages are lost?
I always loose the GPS and NTP i have installed extra…
  MikroTik RouterOS 4.4 (c) 1999-2009       http://www.mikrotik.com/
      longitude: "none"
       latitude: "none"
       altitude: "none"
          speed: "none"
          valid: no
     satellites: 0
[admin@MikroTik] > /interface wireless spectral-scan wlan1
failure: this device can not do spectral scan
[admin@MikroTik] > /system gps set port=usb2 set-system-time=yes enabled=yes
      longitude: "none"
       latitude: "none"
       altitude: "none"
          speed: "none"
          valid: no
     satellites: 0
`x` ~ ` xxxx xx xxx fxxx   x~x x     xxx xx x`xx  f x x  x  x   x x     `xx  x       xxxxf~x   `x` ~     x xx x x xx xx
                x  x x  x  x fxfxx    `x`     xxxx xx xxx  fxxx   x~x x     xxx xx x`xx  f x ~x x xx ~x  xx xxx x     fxx
x    `x` ~ ` xxxx x x xxx fxxx   x~x x     xxx xx x`x  f x x x x x   x fx     `xx  x       xxxxf~x   `x` ~     x xx x x x
x xx x                x fx x x x xfx    `x` ~  f  x x xx  x x  x x xx   xx xx  x`x x x x x fx x x xx  x  xx `xx  xx x  ~x
x    `x` ~  f  x x xx  xx `xx  x x x x  x x `x x xx x xx x  x  xfx xx  x  xx x xx    ~xx    `x` ~  f  x x xx  x x x x x x
x   x x x x x`x   xx  xx x x x x x x  x  x xx x  ~xx    `x`     xxxx x x xxx  fxxx   x~x x     xxx xx x`x  f x `xx  x xx
 ~x x xx xxx x     fxx    `x` ~ ` xxxxxx xxx fxxx   xxx      xxx xx x`x  f x x  x ~x   x  x     `xx  x       xxxxf~x`
`x` ~     x xx x x xx x                  x ~x x ~x x xfx x  `x`     xxxxxx xxx  fxxx   xxx      xxx xx x`x  f x ~x x xx
xxx  xx xxx x     fxx   `x` ~ ` xxxxxx xxx fxxx   xxxx     xxx xx x`x  f x x x x x   `x x     `xx  x       xxxxf~xx    `x
` ~     x xx x x xx xx x                x fx x x x xfx    `x`     xxxxxx xxx  fxxx   xxxx     xxx xx x`x  f x xx  x x x
xx  xx xxx x     fxxx    `x` ~ ` xxxxxx xxx fxxx   xfxx     xxx xx xx  f x x x x x   x x     `xx  x       xxxxf~xx  `x` ~
     x xx x x xx xx x                x fx x x x xfx    `x`     xxxxxx xxx  fxxx   xfxx     xxx xx xx  f x xx x x x x  xx
xxx x
fxx x
Welcome back!
x x  x xfx    `x` ~  f  x x xx  x x  x x xx   xx xx  x`x xx x x fx x x xx  x  xx `xx  xx x  ~x    `x` ~  f  x x xx  xx `x
x  x x x x  x x `x x xx x xx x  x  xfx xx  x  xx x xx    ~xx    `x` ~  f  x x xx  x x x x x xx   x x x x x`x   xx  xx x x
 x x x x  x  x xx x  ~xx    `x`     xxxxx`x xxx  fxxx   x`x x     xxx xx xxx  f x xx xx x  x x xx xxx x     fxx    `x` ~
` xxxxxfx xxx fxxx   x`xx      xxx xx xx x f x x x x x   x  x     `xx  x       xxxxf~xx  `x` ~     x xx x x xx xx x
          x
 fx x x x xfx    `x`     xxxxxfx xxx  fxxx   x`xx      xxx xx xx x f x x x xxx  x x xx xxx x     fxxx
Welcome back!
8,v        6 V  6 6 & 6v
$GPGSV,3,1,12,29,85,143,,08,64,074,29,05,51,212,26,28,42,140,29*7C
$GPGSV,3,2,12,10,42,191,19,15,41,285,33,07,26,065,25,24,20,293,*78
$GPGSV,3,3,12,21,15,318,,19,11,044,,03,08,019,20,06,06,010,18*76
$GPRMC,230849.000,A,5632.8725,N,00818.0394,E,0.35,50.20,201209,,,A*56
$GPGGA,230850.000,5632.8731,N,00818.0394,E,1,05,1.3,25.8,M,43.2,M,,0000*6D
$GPGSA,A,3,08,15,10,28,07,,,,,,,,3.5,1.3,3.2*37
$GPRMC,230850.000,A,5632.8731,N,00818.0394,E,0.66,19.11,201209,,,A*52
$G
PGGA,230851.000,5632.8733,N,00818.0394,E,1,05,1.3,26.4,M,43.2,M,,0000*61
$GPRMC,230851.000,A,5632.8733,N,00818.0394,E,0.18,6.25,201209,,,A*61
$GPGGA,230852.000,5632.8736,N,00818.0393,E,1,05,1.3,26.8,M,43.2,M,,0000*6C
$GPRMC,230852.000,A,5632.8736,N,00818.0393,E,0.06,166.06,201209,,,A*69
$GPGGA,230853.000,5632.8740,N,00818.0395,E,1,05,1.3,26.8,M,43.2,M,,0000*6A
$GPRMC,230853.000,A,5632.8740,N,00818.0395,E,0.46,25.46,201209,,,A*59
$GPGGA,230854.000,5632.8745,N,00818.0398,E,1,05,1.3,26.0,
Welcome back!
2.g 33    6F  Vc F &  F    cF6 &  c  f
$GPGSA,A,3,15,10,28,07,,,,,,,,,9.5,2.1,9.3*3F
$GPRMC,231200.000,A,5632.8674,N,00818.0348,E,0.67,217.61,201209,,,A*67
$GPGGA,231201.000,5632.8669,N,00818.0341,E,1,05,1.4,44.1,M,43.2,M,,0000*6F
$GPGSA,A,3,15,08,10,28,07,,,,,,,,3.4,1.4,3.1*32
$GPRMC,231201.000,A,5632.8669,N,00818.0341,E,0.75,217.64,201209,,,A*65
$GPGGA,231202.000,5632.8672,N,00818.0345,E,1,05,1.4,43.9,M,43.2,M,,0000*6D
$GPRMC,231202.000,A,5632.8672,N,00818.0345,E,0.55,211.88,201209,,,A*6E
$GPGGA,231203.000,5632.8674,N,00818.0341,E,1,05,1.4,41.0,M,43.2,M,,0000*65
$GPRMC,231203.000,A,5632.8674,N,00818.0341,E,0.29,284.75,201209,,,A*68
$GPGGA,231204.000,5632.8682,N,00818.0346,E,1,05,1.4,43.6,M,43.2,M,,0000*68
$GPGSV,3,1,12,08,63,073,21,05,50,211,24,28,43,139,25,15,42,285,33*7A
$GPGSV,3,2,12,10,40,191,26,07,25,066,19,21,15,316,,19,12,043,*74
$GP
GSV,3,3,12,03,08,018,22,06,06,009,18,27,05,242,,18,01,326,*73
$GPRMC,231204.000,A,5632.8682,N,00818
Welcome back!
[admin@MikroTik] >
RouterOS 4.6 has fixed this problem now!
My RB411U has been running almost 2days now, with no problems :slight_smile:
Thx Mikrotik Team…
And maybe i spoke to soon :frowning:
It broke after 2days.
jan/01/2002 01:00:03 system,error,critical System rebooted because of kernel failure
send autosupout to support
what is the channel section on seial port as i cant get gps to work on 4.9
check if you see the port listed in the ports section.
please make the support output file and send it to support@mikrotik.com
