I need to put 3 AP’s on a tower with R52N running 2x2.
Will Mikrotik allow me to GPS sync to avoid interference between APs?
If so can someone tell me what USB based GPS unit I should use with my 433UAH?
Mikrotik does not have support for GPS Sync.
Well, maybe I asked the wrong question.
Does Mikrotik support GPS timing when configured as an AP?
If I have multiple AP’s on a single tower, will this help reduce interference between them?
nope. mikrotik only supports GPS for internal clock sync / ntp. Nothing to do with wireless at the moment.
Nope…you asked the right question. This is the question I was answering. ![]()
