Hi to all,
i am trying to read into the mikrotik the speed of the gps from km/h to knots…
:local speedknots [$speed * 0.5399]
any suggestion?
Hi to all,
any suggestion?
It seems that RouterOS does not support decimals
But to do math, you need parentheses.
local speed 10
:put $speed
:local speedknots ($speed * 5)
:put $speedknots
How about this?
:local speed 10;
:local speedknots (($speed * 5399 / 10000) . "." . (($speed * 5399 / 10) - ($speed * 5399 / 10000 * 1000)));
:put $speedknots;
This is ugly, but it works. ![]()
Note that $speedknots is a string, not a number. Your can print it, but you can not use it for more math.
Will be solved in ROS 7…
thanks man! works perfect ![]()
