GPU accelerated router ?
look what i found on the net :slight_smile:
http://shader.kaist.edu/packetshader/
hope the time when i can upgrade my router with just put my old vga card into it come :slight_smile:
and who say it can take only one card in it ? :slight_smile:
imagine if we can have that in mt
I believe it too. GPUs have an insane amount of power, dedicated power on a very small form-factor.
Maybe some more testing with that software you could come up with some benchmarks and compare with RouterOS?
Very interesting.
Its a them academy project as i trough and donโ€™t even know do it is opensource implementation.
And as i read its needed to install in mt some form of sdk and drivers for vga, donโ€™t even know what more, but i think this will impact hdd size usage and will be limited to only x86 platform.
Mikrotik is closed source and we can just hope . :frowning:
