graph CPU usage, and memory usage on Windows
I’m trying to monitor, and graph CPU usage, and memory on some windows 2000, and 2003 servers.
I followed the steps at
http://forum.mikrotik.com/viewtopic.php?f=8&t=27633&start=0&hilit=CPU+windows
and seem to have the CPU probe talking to The Dude now.
The Memory probe says DOWN, all the time.
The CPU probe says UP all the time, and its graph is just a Blue line a the bottom of the graph.
Does anyone have any more information on how to set these up?
Which cpu probe are you using? Did you make your own or did you use the built in probe?
I used the built in probe. I didn’t change it at all.
Right click on the windows server in the dude and select Tools, snmp walk.
You should see anoter window appear and start filling up with snmp reads of the windows box.
If that doesn’t work than SNMP is not setup correctly.
