It would be great if web graphs could have password protection.
Ok, you can access most graphs from webbox, but it would be nice if you could also access “queue graphs” from there.
You can grant access to selected Ip if you want more security with graphs.
Limiting access by IP is not enough. I actualy cannot understand why web access cannot be protected by password completely. It is not very wise to make it visible to everyone and often, blocking by IP is not possible, or convinient.
There is already option to protect some of the web based interface, why not option to protect everything?
There is one thing, i believe it is a bug. Today I rebooted MT using webbox. Reboot went correctly as expected. However some graphs history was lost. All graphs are set to store data to disk. It seems that ones that were defined for specific simple queues were saved but others which were defined for interfaces were not.
Yes sometimes it happen in my routers too… bug?
Can we request the password feature for the web interface even before it shows that the specific IP is running MikroTik Router OS in big bold letters?
