efiten
February 9, 2014, 7:38pm
1
Hi All,
I’ve been using the “RB951G-2HnD” for a while now, with pleasure.
I added some graphs on the interfaces to monitor the bandwith.
Now, I want to monitor single devices attached to a switch that is connected to the RB.
Is there a way to do this ?
I looked at the Wiki ( http://wiki.mikrotik.com/wiki/Manual:Tools/Graphing ) but don’t know if this is the way to do this, and what I need to use.
No, the graphing feature will only graph certain specific parts of the host router.
payday
February 16, 2014, 10:44pm
4
You can create Queue with target IP numer of single device and then add this queue to graphing.
That’s a good idea, Payday, thanks!
efiten
February 17, 2014, 7:51pm
6
unfortunally I’m not realy into this yet
I have 2 IP’s i want to monitor (just monitor complete traffic up/down) :
PC1 : 10.98.159.220
PC2 : 10.98.159.210
I came to this part, and now i’m stuck, graphs are visible, but no data, still 0 bytes
[admin@MikroTik-on8ar] /queue simple> print
0 name="PC1" target=10.98.159.220/32 parent=none packet-marks=""
priority=8/8 queue=default-small/default-small limit-at=0/0
max-limit=0/0 burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s
1 name="PC2" target=10.98.159.210/32 parent=none packet-marks=""
Try it giving it a limit that is above what it can actually get, but that is not unlimited.
efiten
February 17, 2014, 10:37pm
8
This seems to work, but some queues stay empty, but i’ll let the go on overnight to see if there is a difference.
Let us know how it goes for you
