I’m looking to use MRTG to graph the traffic from queue trees.
I can graph the interface-level traffic with no problem, but I
am not able to find MIBs for the queue trees.
Anyone have a solution to get queue tree stats via SNMP?
Just as background, we define one or more flows for a customer,
then use a queue tree to limit bandwidth. I’d like to create per-
customer graphs from the queue trees, for our own information
and to share with the client on an intranet site.
-Andrew
andrew (at) vivalibre (dot) com
La Ceiba, Honduras
Care to give an example? snmpwalk on my miktrotik 2.8.8 box doesn’t
seem to reveal anything about my defined queue trees or ip firewall mangle flows. It reveals lots of interface stats, and not too much more.
[admin@MikroTik HotSpot] > /queue simple print oid
0 name=.1.3.6.1.4.1.14988.1.1.2.1.1.2.1
bytes-in=.1.3.6.1.4.1.14988.1.1.2.1.1.8.1
bytes-out=.1.3.6.1.4.1.14988.1.1.2.1.1.9.1
packets-in=.1.3.6.1.4.1.14988.1.1.2.1.1.10.1
packets-out=.1.3.6.1.4.1.14988.1.1.2.1.1.11.1
[admin@MikroTik HotSpot] > /queue tree print oid
0 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777228
flow=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777228
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.5.16777228
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777228
I have set up mrtg for my simple queues and here's example for the first
queue:
YLegend[$CFGNAME]: $SIMPLEQUEUENAME queue bits per second
Options[$CFGNAME]: growright, bits
Target[$CFGNAME]:
.1.3.6.1.4.1.14988.1.1.2.1.1.8.1&.1.3.6.1.4.1.14988.1.1.2.1.1.9.1:$COMMUNITY
@$IPADDRESS
MaxBytes[$CFGNAME]: 100000
Legend1[$CFGNAME]: Bits Recieved Per Second
Legend2[$CFGNAME]: Bits Sent Per Second
Legend3[$CFGNAME]: Maximal 5 Minute...
Legend4[$CFGNAME]: Maximal 5 Minute...
LegendI[$CFGNAME]: In:
LegendO[$CFGNAME]: Out:
Title[$CFGNAME]: $SIMPLEQUEUENAME queue bits per second
PageTop[$CFGNAME]:
Hi all.
I having on use already 45 days a script modified of cfgmaker of mikrotik.
The modification is the name of file for the interface of pppoe connection. Now the filename of report
is (example): the name of interface well, the filename of report is: myusername.html
the .log .png files is the same.
My knowledge of perl is very poor (like my english). The modification of cfgmaker file is brute.
You can use the last MRTG 2.10.0pre1. I use this cfgmaker file modificated for previous version of mrtg, too.
The only problem of this solution is when a user connect, then disconnect after 12 hours. The report of
this mrtg is fine, but after the disconnection if the user connect again, the report of mrtg is a line. You can
see that if you try this.
I have a cron file (scheduled tasks) with this .bat file every 5 minutes
-----file.bat —
interface-number (or OID) change every user connection
using cfgmaker whit option
-ifref=nr -ifdescr=name
MRTG work fine and create graphs… but after user reconnection, MRTG loose history because MRTG use interface-name in .html e .log file… and don’t match…
-ifref=name, -ifdescr=name
MRTG/SNMP seem not able to read data; I suppose the problem is name of PPPoE interfaces, like …
A solution can be modifiy cfgmaker (when using option -ifref=nr ifdescr=name) to use interface-name (like ) as namefile of .html and .log file where MRTG store data and interface-number for target (readed by SNMP). So after user disconnect/connect MRTG will store data always in a file named like .log
