Hello! I managed to raise the GRE tunnel between the two routers. Local network pings. does not come out to raise IPSec. Here is a detailed hardware configuration. In what could be the problem?
СONFIG FOR SITE A
add chain=srcnat action=masquerade out-interface=ppp-out1
add address=192.168.1.1/24 interface=ether2
/interface gre add name=myGre remote-address=10.250.18.3 local-address=10.250.18.1
add address=172.16.1.1/30 interface=myGre
add dst-address=192.168.2.0/24 gateway=172.16.1.2
/ip ipsec peer
add address=10.250.18.3/32 port=500 auth-method=pre-shared-key dh-group=modp1024
disabled=no dpd-interval=disable-dpd dpd-maximum-failures=1
enc-algorithm=3des exchange-mode=main generate-policy=no hash-algorithm=
md5 lifebytes=0 lifetime=1d nat-traversal=no proposal-check=obey secret=
test send-initial-contact=yes
/ip ipsec policy
add action=encrypt disabled=no dst-address=192.168.2.0/24 dst-port=any
ipsec-protocols=esp level=require priority=0 proposal=default protocol=
all sa-dst-address=10.250.18.3 sa-src-address=10.250.18.1 src-address=
192.168.1.0/24 src-port=any tunnel=yes
add action=accept chain=srcnat comment="NAT bypass" disabled=no dst-address=
192.168.0.0/16 out-interface=ppp-out1
add action=masquerade chain=srcnat comment="default PAT" disabled=no out-interface=
ppp-out1
[admin@MikroTik] /ip firewall filter> print
0 chain=input action=accept protocol=udp dst-port=500
1 chain=input action=accept protocol=ipsec-ah
2 chain=input action=accept protocol=ipsec-esp
3 ;;; default configuration
chain=input action=accept protocol=icmp
4 ;;; default configuration
chain=input action=accept connection-state=established
5 ;;; default configuration
chain=input action=accept connection-state=related
[admin@MikroTik] /ip> route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 10.112.112.133 1
1 ADC 10.112.112.133/32 10.250.18.3 ppp-out1 0
2 ADC 172.16.1.0/30 172.16.1.2 myGre 0
3 A S 192.168.1.0/24 172.16.1.1 1
4 ADC 192.168.2.0/24 192.168.2.1 bridge-local 0
[admin@MikroTik] /ip ipsec peer> print
Flags: X - disabled
0 address=10.250.18.1/32 port=500 auth-method=pre-shared-key secret="test" generate-policy=no exchange-mode=main send-initial-contact=yes nat-traversal=no
my-id-user-fqdn="" proposal-check=obey hash-algorithm=md5 enc-algorithm=3des dh-group=modp1024 lifetime=1d lifebytes=0 dpd-interval=disable-dpd dpd-maximum-failures=1
[admin@MikroTik] /ip ipsec policy> print
Flags: X - disabled, D - dynamic, I - inactive
0 src-address=192.168.2.0/24 src-port=any dst-address=192.168.1.0/24 dst-port=any protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=yes
sa-src-address=10.250.18.3 sa-dst-address=10.250.18.1 proposal=default priority=0
