Hello
I have two locations connected to each other through a GRE tunnel without ipsec. Everything goes perfectly until the moment when something changes at night and the speed drops from 7-800 Mb to 5-6 Mb. I discovered that if I activate ipsec and then deactivate ipsec, the speed comes back. Because what I described happens almost every night and every morning I connect with winbox to the two mikrotiks to redo the GRE, could I automate it through a script that runs every morning at a certain time?
Basically, the script must set GRE with a password for IPsec, then set the same GRE without IPsec.
Can such a thing be done?
Look at the System->Scheduler function
