GRE not working
dear all mikrotik fans. hi
i am quite new to mikrotik networking so please forgive me beforehand.
i am trying to setup a basic gre tunnel between cisco isr4300 and a 951ui-2hnd routers. on cisco side everything seems to be set ok; including: tunnel state is reported up/up, wan interface ip is set, lan interface ip is set … here is the ip plan:
cisco:
wan ip: 1.1.1.2/30
lan ip: 192.168.253.1/30
tunnel ip: 10.10.10.1/30
routing report:
10.10.10.0/30 is directly connected, Tunnel0
10.10.10.1/32 is directly connected, Tunnel0
172.16.0.0/24 is subnetted, 2 subnets
172.16.1.0 [1/0] via 10.10.10.2
172.16.2.0 [1/0] via 10.10.10.2
on mikrotik side, i’ve uploaded the config file to see where i’ve gone wrong or missing:
# jan/02/1970 00:59:17 by RouterOS 6.44.5
# software id = 0G7Y-54W3
# model = 951Ui-2HnD
# serial number = B8570BE4F3C7
add admin-mac=C4:AD:34:82:55:8B auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=ether1_WAN
set [ find default-name=ether2 ] name=ether2_LAN
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=\
    MikroTik-82558F wireless-protocol=802.11
/interface gre
add local-address=2.2.2.2 name=tunnel0 remote-address=1.1.1.2
add comment=defconf name=WAN
add comment=defconf name=LAN
add bridge=bridge comment=defconf interface=ether2_LAN
add comment=defconf interface=ether1_WAN list=WAN
add address=2.2.2.2/30 interface=ether1_WAN network=2.2.2.0
add address=172.16.2.1/24 interface=ether2_LAN network=172.16.2.0
add address=10.10.10.2/30 interface=tunnel0 network=10.10.10.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
    ether1_WAN
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
    established,related,untracked disabled=yes
    invalid disabled=yes
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes \
    protocol=icmp
    disabled=yes in-interface-list=!LAN
    disabled=yes ipsec-policy=in,ipsec
    disabled=yes ipsec-policy=out,ipsec
    connection-state=established,related disabled=yes
    connection-state=invalid disabled=yes
    connection-state=new disabled=yes in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
add action=accept chain=srcnat dst-address=192.168.253.0/24 src-address=\
    172.16.2.0/24
add action=masquerade chain=srcnat disabled=yes out-interface=ether1_WAN
add distance=1 dst-address=192.168.253.0/24 gateway=10.10.10.1
/tool mac-server
/tool mac-server mac-winbox
right now i cannot ping the tunnel on both sides, neither cisco-to-mikrotik nor mikrotik-to-cisco.
kind regards.
Try this before the drop rule (#4):
add chain=input src-address=1.1.1.2 protocol=gre action=accept
thank you so much Sob.
that didn’t work unfortunately. seems like the tunnel never gets up because of a routing problem. when i ping cisco-side tunnel ip from inside mikrotik it prints “no route to host”. i have tried both connecting these two directly using network cables as well as emulation in envionments like gns3 or eve-ng. yet again, no success! the result is exactly the same: “no route to host” + Success rate is 0 percent (0/5)
i’m pretty perplexed.
regards.
I only now noticed that all your firewall rules are disabled, so previous advice couldn’t help, because everything is already allowed.
But why it doesn’t work. I thought that 2.2.2.2 and 1.1.1.2 were just masked public addresses and that you have default route from DHCP (although it would be slightly unusual to have both DHCP and static address). But if it’s test with direct connection and nothing from DHCP, it can’t work, because there’s no route to reach remote 1.1.1.2.
dear Sob, hi
yes right now the routers are directly connected with non-valid static IPs. how can i get it to work? by working i mean being able to ping two sides of the gre tunnel from inside the routers. in other words, how can i establish correct static routes between these two. Or, why do you say technically that “there’s no route to reach remote 1.1.1.2”? i expect the two should ping each others static ip. is this expectation wrong?
let me clarify that i have access to public valid IPs and i am able to test this, as i suppose, simple scenario between the really public routers. may this solve the reachability?
regards.
as an update to this issue, i tried to do it as basic as possible. right now, two static non-public IPs are set on directly connected ports of the two routers. now, i can cisco router IP from mikrotik but pinging from cisco to mikrotik fails. seems like there is a setting on mikrotik that blocks connectivity from cisco side. any ideas?
by the way, mikrotik 951ui-2hnd have default configuration with it, ain’t know if this matters.
GUYS COMMON I REALLY NEED HELP IN HERE!
regards.
What’s reachable depends on routes, and routes depend on masks. If you have ether1_WAN with 2.2.2.2/30 and that’s connected directly to other router, then if they should communicate, other routes needs to have 2.2.2.1/30, because it’s in given subnet.
thanks to all buddies, this issue is solved. the problem was way more of a basic thing.
