This is a cross-post from the Subreddit, no Deja Vu intended.
today I updated two CHR instances from 7.20.6 to 7.25.1 and having some issues with GRE (over IPSec). This configuration was working for over a year just fine.
Environment:
CHR on AWS <-> 3x IPSec Tunnel to a FortiGate with 3 WAN IFs <-> CHR behind FortiGate
Are there any known problems when the Remote Address of the GRE Tunnel Interface is behind an IPSec Tunnel (seperate Tunnel, not the IPSec secret within the GRE configuration)? It looks to me that no GRE packets are generated or at least not routed into the IPSec tunnel. I disabled Allow FastPath, but that did not make any difference.
I can ping over the IPSec tunnel just fine, so routing isn't an issue.
In an act of desperation I removed the Local Address from the GRE tunnel (AWS), hit apply, added the Local Address again and hit OK. The GRE tunnel went back up. I did the same for the other 2 GRE tunnels, but only one more came up.
All GRE tunnels having distinct Local and Remote Addresses and each GRE has it's own IPSec counterpart.
It might have to do with the latest changes in 7.25, but I cannot say for sure because 7.20.6 was released 11 months ago with a lot of updates inbetween.
Help highly appreciated.
/ip ipsec proposal
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc lifetime=6h name=P2 pfs-group=modp2048
/interface gre
add allow-fast-path=no local-address=10.5.0.209 name=GRE_HQ-WAN1 remote-address=10.5.0.2
add allow-fast-path=no local-address=10.5.0.225 name=GRE_HQ-WAN2 remote-address=10.5.0.3
add allow-fast-path=no local-address=10.5.0.241 name=GRE_HQ-WAN3 remote-address=10.5.0.4
add address=10.0.254.16/24 interface=ether2 network=10.0.254.0
add address=10.5.0.209/28 interface=lo network=10.5.0.208
add address=10.5.0.225/28 interface=lo network=10.5.0.224
add address=10.5.0.241/28 interface=lo network=10.5.0.240
add address=10.5.0.78/28 interface=GRE_HQ-WAN3 network=10.5.0.64
add address=10.5.0.62/28 interface=GRE_HQ-WAN2 network=10.5.0.48
add address=10.5.0.46/28 interface=GRE_HQ-WAN1 network=10.5.0.32
add action=accept chain=srcnat dst-address=10.5.0.0/24 src-address=10.5.0.0/24
add check-gateway=ping disabled=no distance=1 dst-address=192.168.4.128/28 gateway=10.5.0.33 routing-table=main scope=\
30 target-scope=10
add check-gateway=ping disabled=no distance=2 dst-address=192.168.4.128/28 gateway=10.5.0.49 routing-table=main scope=\
30 target-scope=10
add check-gateway=ping disabled=no distance=3 dst-address=192.168.4.128/28 gateway=10.5.0.65 routing-table=main scope=\
30 target-scope=10
add check-gateway=none disabled=no dst-address=10.0.240.0/24 gateway=10.0.254.1 routing-table=main
/ip ipsec profile
add dh-group=modp2048 enc-algorithm=aes-256,3des hash-algorithm=sha256 name=P1 prf-algorithm=sha256
/ip ipsec peer
add address=xxx.xx.xxx.124/32 exchange-mode=ike2 name="HQ (wan2)" profile=P1
add address=xx.xxx.xxx.127/32 exchange-mode=ike2 name="HQ (wan1)" profile=P1
add address=xx.xx.xxx.101/32 exchange-mode=ike2 name="HQ (wan3)" profile=P1
/ip ipsec policy
add dst-address=10.5.0.4/32 peer="HQ (wan3)" proposal=P2 src-address=10.5.0.240/28 tunnel=yes
add dst-address=10.5.0.3/32 peer="HQ (wan2)" proposal=P2 src-address=10.5.0.224/28 tunnel=yes
add dst-address=10.5.0.2/32 peer="HQ (wan1)" proposal=P2 src-address=10.5.0.208/28 tunnel=yes
--Michael
