Hi Everyone!
We have two routers configured with GRE tunnel and have established the connection between two routers. but non of the routers cant ping internal subnet ips from each side. all the routes are learned from each routers and filled with routing table but still no access. both routers running BGP along with the GRE tunnel. I only configured GRE Tunnel and assigned LAN subnet to bridge interface/nat rule as masquerade/BGP with internal IP subnet so other router will learn. GRE is established. Other than what I configured, are there any other configs to be made to make the internal ips connectivity.
When a traceroute performed from one router to other router’s internal ip address, routing fails from other routers GRE interface.
Please refer to below script from client router
add l2mtu=1598 name=bridge1
/interface gre
add comment=9472xxxxxxx dscp=inherit name=GRE-RDB-BR-Baddegama
remote-address=10.134.0.210(Remote MKT Router)
/ip neighbor discovery
set GRE-RDB-BR-Baddegama comment=9472xxxxxxx
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
mac-cookie-timeout=3d
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc,aes-192-cbc,aes-256-cbc
/routing bgp instance
set default as=65501
/system logging action
set 3 remote=0.0.0.0
add address=10.2.17.1/24 interface=bridge1 network=10.2.17.0 (LAN IP Subnet for local Clients)
add address=20.1.158.2/24(Client router GRE Interface IP) interface=GRE-RDB-BR-Mirisswatte network=20.1.158.0
/ip hotspot user
add comment=“counters and limits for trial users” name=default-trial
/ip ipsec policy
add template=yes
/ip upnp
set allow-disable-external-interface=no
/routing bgp network
add network=10.2.17.0/24(Local subnet)
/routing bgp peer
add name=peer1 remote-address=20.1.158.1(Remote MKT GRE Interface) remote-as=65501
Please help me to solve this issue!
Thanks in advance! ![]()
