I have a great problem!!, when I use a routerboard by CM9 mini pci
on 802.11b the signal works only for 5 or 10 meters, if I use o Mini pci
prism sl 2511 mp plus 2.10 I have a very goor and long range of a lot of
Km… Why? Is a problem of setting of minipci ?? it possible to have a correct setting of wireless on mikrotik interface?
best regards
serenida ![]()
CM9 has less output power that PRISM, can you post your wireless configuration so we can welp you more? a tell us what type of antennas, pigtail, etc do you use, and what version of MT you have installed.
Regards
oK, I use Prism as:
GENERAL
wlan1
mtu: 1500
arp: enabled
WIRELESS
mode: ap bridge
band:2.4ghz
frequency: 2437
security profile: defoult
frequency mode: regulatory domain
country: italy
antenna gain: 0
prism cadtype: 200mw
DATA RATES
rate: defoult
ADVANCED
max stat…:2007
I use a MT VERSION 2.9.6, a sectorial antenna pacwireless and a pigtail ufl-N from card to antenna .
How I can do for the CM9 minipci?
best regards
serenida
First upgrade to 2.9.12, then try again with the CM9. The CM9 is atheros based chipset so the configuration is diferent. Post the results after the upgrade
Regards
I have upgrade to 2.9.12 but I have not a good test!!!
I have the problem too…
If I test by minipci Wireless miniPCI-Module Compex WLM54G ??
best regards
5 metter only? maybe wrong antenna jack?
Totally agree ![]()
