Groove 2.4ghz
I will buy hundreds if you can make this product in 2.4ghz frequency. Please make this Mikrotik. Whats your thoughts?
I’ll second that - just installed 90 Engenius3500 when 2.4 groove would of been much better.
Would be nice if it was 24dbm not 20dbm. That way there is a lot of nice priced antennas to go with the groove. If you can go higher that. That still would be nice.
The groove has 15dbm at 54mbps which is almost nothing. I would need a very high dbi antenna. Which price goes up. If we had little higher dbi the overall price would be good. Thanks in advance.
I see the omnitik is 400mw. Why not the groove? 400mw will work for 5ghz and 2.4ghz.
if you can make it like the Altai C1 spec, we will more than happy buy few hundred unit.
another vote.
The 2.4GHz Mikrotik equipment has seemed a little left out of late.
Mikrotik are you trying to not use amplifers in your equipment?
While I like and sometimes need the higher power units, I see why they don’t have amps on every device.
The Crossroads I have sometimes do not like the lower power settings. I have a few that I could swap out for lower power units, however they are not easy to get to. If set below 10dBm then we have some issues.
The RB711h2n has 27dB tx, sounds like it has an amp to me. I am looking forward to trying it, as well as a 2GHz Groove and Omnitik. I’m feeling a little left out by all the 5GHz focus.
I would like it if MT would bring a 900MHz 802.11n option to the table. Ubiquiti’s M9 products are great and all, but you cannot disable TDMA and it will cause self interference.
anything over 200mw is amped.
A minipci 802.11n 30db card is coming out soon. We can use that card with mikrotik.
It might be 28db. I am talking with the manufacturer.
Actually I dont care if the power is more than 200mw. I want the groove 2.4ghz.
I want to use this for my 2.4ghz clients.
  1. Less electronics, less chance esd will aim at it.
  2. Very easy installation
  3. Light wait
  4. Very flexible for antenna sizes
  5. Very cheap replacement costs.
  6. Its Mikrotik!!!
who are you talking to?
“I like to do all the talking myself. It saves time, and prevents arguments.” - Oscar Wilde
Regards,
haha that is awesome. Thanks for the humor. I guess your right. :wink:
a groove in 2.4GHz kills all picostations M2 I use as street access point
I would look at this the other way. If something dies because of simple interference, it’s not a good sign.
:smiley: :smiley: :smiley:
sorry!!
I mean: “a 2.4GHz Groove “commercially” kills picostations”
Sorry, I misunderstood that statement :slight_smile:
