Groove 52 ac configration
Hello, I need some help
GrooveA 52 is installed on a boat to access Internet in marinas. It will be connected it to a router WiFi on the WAN port to distribute (LAN ports and WiFi) Internet in the boat. At first, I have connected it to my laptop (Ethernet port) to check it. Using WinBox / Quick set, it configured automatically to WISP AP - Bridge. I changed to CPE - router (am I correct ?) and could connect to a local WiFi network. DCHP is disabled and I tried both NAT enabled and disabled. W10 message is “unidentified network / no Internet access”. Whatever tweaks I try with WinBox interface, I cannot access Internet. Signal is good and I know there is an Internet connection through WiFi network I access. What is the correct configuration ? I searched the wiki Mikrotik and forum but could not find an answer to my problem.
Patrice (in a remote place)
I am having same problem. Out of the box, hooked up directly to computer and only lights up bottom LED. Will not recognize 192.168.88.1 nor ping.
Also tried this post:
http://forum.mikrotik.com/t/boat-setup-for-groovea-52hpn-and-rb-951ui-2hnd/83681/1
Do these things get returned to distributors with config messed up and and they resell them?
Please use the Netinstall utility to reinstall the device:
http://wiki.mikrotik.com/wiki/Manual:Netinstall
Install latest current or bugfix version on router:
https://mikrotik.com/download
Afterwards reset router to default configuration:
https://wiki.mikrotik.com/wiki/Manual:Reset
Now try to connect to this device:
https://i.mt.lv/routerboard/files/Groove-qg.pdf
