They apparently do not support middle channel/channel shifting (2414,2419,2424, etc)? Tried ros 5.25-6.4
Its working fine on 711’s.
Update:
adding the custom channels show unsupported. And it only works on 711
/interface wireless channels
add band=2ghz-b/g/n frequency=2414 list=Standard-Shift name=ch1-2414 width=10
add band=2ghz-b/g/n frequency=2419 list=Standard-Shift name=ch2-2419 width=10
add band=2ghz-b/g/n frequency=2424 list=Standard-Shift name=ch3-2424 width=10
add band=2ghz-b/g/n frequency=2429 list=Standard-Shift name=ch4-2429 width=10
add band=2ghz-b/g/n frequency=2434 list=Standard-Shift name=ch5-2434 width=10
add band=2ghz-b/g/n frequency=2439 list=Standard-Shift name=ch6-2439 width=10
add band=2ghz-b/g/n frequency=2444 list=Standard-Shift name=ch7-2444 width=10
add band=2ghz-b/g/n frequency=2449 list=Standard-Shift name=ch8-2449 width=10
add band=2ghz-b/g/n frequency=2454 list=Standard-Shift name=ch9-2454 width=10
add band=2ghz-b/g/n frequency=2459 list=Standard-Shift name=ch10-2459 width=10
add band=2ghz-b/g/n frequency=2464 list=Standard-Shift name=ch11-2464 width=10
It appears that “channel shifting” is only supported on AR92xx cards and all new RB’s are running the AR93xx. Will shifting be supported on AR93xx cards?
Hardware support
Non standard center frequency and width channels can only be used with interfaces that support it.
Currently only Atheros AR92xx based chips support non-standard center frequencies and widths with the following ranges:
center frequency range: 2200MHz-2500MHz with step 0.5MHz (500KHz), width range: 2.5MHz-30MHz width step 0.5MHz (500KHz);
center frequency range: 4800MHz-6100MHz with step 0.5MHz (500KHz), width range: 2.5MHz-30MHz width step 0.5MHz (500KHz);
http://wiki.mikrotik.com/wiki/Manual:Wireless_Advanced_Channels#Hardware_support
