I have a customer i just installed several Groove 52HPn AP’s alternating channels etc.
Microsoft and Android devices connect fine to wireless, Apple do not.
In troubleshooting this with another Groove i have offsite, i rolled the 6.7 back to 4.17 by adding 4.17 upgrade package files into file area of Mikrotik, then issued a /system package downgrade the device rebooted and the lights light up it makes boot sounds.
But winbox and IP can not connect.
I have reset config by reset button, and removed routerboard from housing and performed jumper reset probably 20 times. I have done this with other Mikrotiks and i remember sometimes it took me a few tries.
I have console cables… is there a way to console into this board and reset to 5 or newer, im thinking 4.7 just wont run on this board?
That is exactly what i was looking for.
So i got the Groove to boot PXE and the Netinstall sees the device, i have tried routeros-mipsbe 5.26 and 6.7 and they both fail after copying, then installing for at least 60 seconds, it looks like its going to install then goes to a failed state.
Installation failed: no response from router, timout
If i reset the groove to PXE i can get it back into Netinstall.
what netinstall version are you using?
Make sure that you use the latest Netinstall version - v6.7 currently.
Also make sure that the IP address in the Netbooting is from the same IP network that your PCs IP.
indeed they are on same subnet, using netinstall 6.7
the groove and its MAC show up in the Netinstall Router/Drivers window
when i select the package, it shows my previous key, its correct, the routeros-mipsbe file shows downloading to device then installing, them bombs out.
