HI,
I have a problem with the Groove 52HPn frequencies, I’m using 2.4GHz with a 5MHz Bandwidth B/G/N.
I have set frequency mode to superchannel and country to South Africa.
My ROS is 6.6 with Firmware 3.10
Problem;
I have some interference issues at high site and need now and then to change the frequency to a in between channel eg. 2439 or 2444 where this is not a listed channel, this is only to have a moment for the interference to go away and keep my clients connected to the internet, after an hour or two I reset to a normal channel again.
With the Groove 52HPn I can’t use these frequencies except for the normal channels.
It doesn’t even pickup the sectors on the scan function.
Is there a way to get pass this as I don’t know what ells to try.
Thank you
