I have one link with two Groove 5HN but my troughput is very very low (10mbit) are normal?
Thanks.
Thanks.
whats is the result you seek.
what is the distance between sites.
wht is the condition of los, fresnel etc.
distance 13 (i have another link at 2km with same problem) km -56db tx and rx, I use jirous 24db ext dual and I would 50mbit simmetric… it’s possible?
Keep channel width at 20 MHz and check for frequency band that gives the highest CCQ. Do you have clear LOS.
We are running Groove 5Hn over 30 km and delivering more than 15 mbps. Bandwidth tests has shown us 100+mbps.
Try using 20/40 and Wireless N. You will get excellent throughput if the LOS is clear.
can you show your config?
my ccq are 70%
