The light comes on it beeps then light shuts off.
Does anyone know how I can get it working again?
How do I revert back to the previous version? Would that even help?
If all the LEDs turn off, it could indicate a power problem. Have you tried another power adapter?
Its Poe, and other routers work fine from the cable.
a software upgrade can’t cause the unit not to turn on. it might be a hardware related issue. I suggest contacting the seller
