Which is the correct way resetting the Groove A-52HPn into a factory settings? There is few different instructions but none of them seem to be working for my AP, not expecting it to be totally bricked, have had same problem resetting in past but do not recall how got it working then..
So far have tried
- While AP on hold the reset button for 20 sec
- While turning on the AP hold the reset button until the leds started to blink
- While turning on the AP hold the reset button for 20 sec
- 30-30-30 - While AP on hold hold the reset button for 30 sec, turned the AP off and continued holding the reset button for 30 sec, turned the AP on and hold the reset button for 30 sec
Winbox is still not making connection but giving a timeout..
I know some others have had similar issues:
http://forum.mikrotik.com/t/new-groove-a-52hpn/93103/3
Firewall is not an issue with my setup.
