Groove A-52HPn - update to 6.7 disappeared
Update to 6.7 for Groove A-52HPn disappeared from “Check for updates”. It was in place two days ago, but not now. Is 52HPn still compatible with 6.7 or not?
It is!
What do you see in the “Check for updates” menu? Do you have internet connectivity?
Current version 5.26
Last verion 5.26
System is already up to date
Internet connection is fine.
v5 doesn’t automatically update to v6, this one you must upload manually.
this is the file you need to copy to your device (and reboot):
http://download2.mikrotik.com/routeros/6.7/routeros-mipsbe-6.7.npk
