I do not any light on the groove and can’t connect to it via winbox!
Check power supply, POE injector and UTP cable.
That is the first thing I checked ,light come on when I connect cable to it (4 lights) but after nothing even if I reset it!
This is normal, hear you the two beeps?
If yes the groove is starting up
