Groove A2Hn Mesh or Mulit-Repeater set up
Hello Everyone,
I want to create either a mesh or a string of repeaters (between two access points) set up using Groove A2Hn hardware.
I’ve got single repeater setup working fine (AP-Repeater-AP, using two SSIDs) and have made some good progress with a WDS linked mesh network (with three Grooves all talking/linking OK within the mesh - dynamic set up), but much of the information in the Wiki suggests multi channel set ups are required for the client access side- which I believe cannot be done with the Groove.
The main issue I have with my mesh set up is the ethernet/WLAN client access (I contribute much of this to my limited experience at this stage)
Most of my Mikrotik Wiki searches have provided the same advise.
Example: http://wiki.mikrotik.com/wiki/Testwiki/Advanced_MikroTik_Wireless_networks
A multi-repeater set up is my first preference (AP-REP-REP-…REP-AP), but I am interested in mesh setups too.
If anyone can point me to some appropriate Wiki pages or share their Groove experience I would be most appreciative.
Thank you for your time.
Even though no-body assisted me on this one (not even a whisper), I did manage to get a fully working MESH system, with Client Portals running using MikroTik Groove A-2Hn routers.
So if you see this…its OK, I sorted it all out.
Cheers
