Groove A52hpn Wireless Range problem
Hi. First off all, I have almost no knowledge on this.
I have a groove A52hpn plugged with my Starlink dish.
It worked with the original small antenna, but with not enought range. So I bought a 15dbi omni antenna. It got a little better, but it the range was too low (like 150m) yet.
But a few days later the range dropped a lot and now I can only use it in a 10m range. More than this it does not work. I tested the old antenna and has the same issue.
The only light that is on (blinking) is the Lan. No wireless lights gets on during usage.
I've reseted it, but nothing changed.
It is a rural area, not much interference going on.
[admin@MikroTik] > export hide-sensitive
jan/01/2002 01:32:37 by RouterOS 6.49.7
software id = 02KU-URB5
model = Groove A-52HPn r2
serial number = D0280DE0E069
add name=bridge1 protocol-mode=none
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=2 band=2ghz-b/g/n channel-width=
20/40mhz-eC country=no_country_set disabled=no frequency=2432
frequency-mode=manual-txpower mode=ap-bridge radio-name=AP-HOTSPOT1 ssid=
HOTSPOT1 wireless-protocol=802.11 wps-mode=disabled
add bridge=bridge1 interface=wlan1
add address=192.168.100.1/24 comment=IP-BRIDGE interface=bridge1 network=
192.168.100.0
set servers=8.8.8.8,8.8.4.4
add distance=1 gateway=192.168.100.1
