groove A5hn as access point
im very admirer with this product .i read carefully the charactors as what if we used as access point..
it have license level 4..what i know that this level related with 20 active users.
my question is if we connect this devise with ominiantenna 5ghz /15dbi ..is it true that this access point will active just with 20 active online users and what happen if the users increase to 30/40
i mean is this devise is just for 20 active users ? or something else?
The number of users depends on the speed offered, overall signal strength for the clients, speed of the processor and how you have the unit configured.
I’ve got 28 on an 802.11G card right now, that is as many as I want. Adding capacity soon. 802.11N should be able to handle more, just how many, I haven’t pushed it yet.
this is not true. where did you read this? Level4 has no such limit for wireless users. the limit is 2007 users (theoretical limit), actual limitation depends on how much speed you want for each customer.
thank you very much but what does the number 20 means in the following page i mean in field license 4
http://wiki.mikrotik.com/wiki/Manual:License#License_Levels
It is the number of users (admins) logged on to the ROS. The number of wireless clients is unlimited
Level 3 - Bridge = 1 client
Level 4 - AP Bridge = unlimited clients
also wrong. it’s “USER MANAGER” sessions if you use the product which is called “MIKROTIK USER MANAGER”
Why is there a user limit at all and where does this number “2007” come from?
Thanks, Herakles
http://wiki.mikrotik.com/wiki/Manual:Interface/Wireless
2007 is a hardware limit.
i believe the number of users stated on license levels are about the actual user (like hotspot, pppoe etc)
not the hardware user(device) limiting .
level4=20
level5=200
level6=unlimited
execuse me to all my friends ..but suppose you would like to make the above device as a hotspot station(( access point/bridge ))
and you have actually 50 active users connected with this device all of them users open yahoo massenger in the same time
of course you connected the device with high internet bandwith service source
are all of these 50 users will not face any proplem with internet ??
with thanksssssssssss…
please need answer…because my information in this issue is weak
can someone help me with thanks
If all of these users indeed do nothing else than look at the messenger screen (which is unreal.) and all have good signals in both directions and there is no interference around and there is good S/N ratio for all units and other wireless related settings are tuned than that is possible.
But in real live it is not.
For 50 active users you are more looking to a rb800.
But still, if they all are file sharing with 10Mb and you would have 500Mb capacity behind it you still have problems.
thanks to all my frinds for there kindly pursuit
last question what dose this phrase mean..??
any body use chatting with there friends and open web camera ..is unreal.!!!
no! like I said above, “20” is only a limitation for “USER MANAGER” users. USER MANAGER is a specific program: http://wiki.mikrotik.com/wiki/User_Manager/Introduction#What_is_User_Manager
If you do not use this program, THERE ARE NO LIMITATIONS! For hotspot, the limit of ACTIVE users in Level4 is 200 not 20!
Exactly. If you have 50 guys only having their laptop on and only one application running, yahoo messenger, but only the txt messaging then it is possible.
If all 50 start using the video apart from running out of bandwidth the CPU of the groove just can’t handle all that traffic and your network will start becoming very slow because their can be only one station at the time, and only in one direction, be served.
Apart from that, any PC, laptop or Pad is also doing several other things. Virus update, Windows upgrade, all kind of little programs that go on line in the background, the browser communicating with several servers (adds, banners, cookies etc.). Even a laptop not been touched for 10 mins is still sending and receiving some data.
Very basically what an AP does in NV2 is this:
step 1 Send to client A
step 2 Receive from client A
step 3 Send to client B
step 4 Receive from client B
step 5 Send to client C
step 6 Receive from client C
Now, you can imagine if these clients hardly have to receive anything from the AP and also hardly have to send anything back to the AP (so they are connected (=active) but basically doing nothing), the AP can easy cycle through all his clients and within relative short time serve client A again.
Now imagine to have 50 clients. And they all have their video ON. So now suddenly the AP has to send bulk of data to client A, then receive bulk of date from A, than send to B, receive from B, than C etc. etc. etc. After having all 50 stations served AP has to back at A again in time so “A”-user is not aware he has not been served for some microseconds.
You can imagine this becomes very hard. The AP’s CPU has to work very fast to perform all this work in time.
CPU of Groove is just not capable of doing this all. If you need so much work to be processed you need more muscle!
What normis means with ´active´ is “associated to AP”. The hardware limitation is 2007 which can be read as “unlimited” because not an AP in the world would be able to serve so many stations without creating delays in the system.
In authentication server (hotspot, user manager); the amount of registered users (=active) that are allowed .. This is more a software limitation build in for sales sake. (Or not? MT?)
excellent…very very excellent
thank you very much
thank to all friends especially
normis and wirelessrudy
