Hello.
I have a couple of Grooves connected to various AP that are emitting same ssid and same key.
My issue is that the Groove at startup connect to AP1 and after that moves it to AP2 area.
What I found is that Groove keep stuck to AP1 and not roam to the AP2 until signal get really really bad and normal disconnection occur, after that it connect to AP2.
In RouterOS manual say that when in station mode and wireless protocol is set to 802.11 mode it will search periodically for best AP and connect to it, it will search more often if signal get worse.
I have configured wireless protocol to 802.11 as manual say and try several times and minutes and don’t see the roaming occur. I had waited more than 30 minutes.
Anyone know exactly how RouterOS manage the roaming as client or how to configure the RouterOS to correctly work the roaming capability it have?
