groove configuration not possible through network
I’m a beginner and has problems accessing the configuration of the Groove.
wired connections: ISPs modem - ISP router (with DHCP in the range 192.168.0.1/250) - Groove (for wireless connections)
SO I programmed the Groove (straigt cable from pc to groove ad static IP adres from pc in default range groove 192.168.88.*) to AP, bridge mode, set static IP 192.168.0.199 and gateway 192.168.0.1, changed password and applied.
Then, plugged in the groove (of course with POE) into the ISP router.
Then I make a wireless connection to the ISP router network (my pc gets via dhcp address 192.168.0.125).
But I can’t access the Groove via webpage 192.168.0.199, also not via winbox. Also in the usage table from the ISP router, I see no sessions for the groove.
Please advice, because I want to change the groove config, and this is now only possible with a reset to default and do the full configuration again. I’ve tried a 10 different things, but no success :frowning:
Many thanks.
Use winbox.
