Groove yo Groove backup restore
Hello, I have a lot of groove A 52 HPn and I need to configure all t the same, changing only the last octet of IP and router name.
I have just configured the first, make a config backup with Winbox and also I did a “export file=config”.
Now I am trying to upload this config to another Groove, the backup fail, apply some part odd the config but not all and the “import config.RSC” failed too, stop with this in the console "interface: ".
If I try to import another time it fail.
How can I generate a base config file for all my Grooves?
I came from Ubiquiti devices and with Ubiquiti config file you can generate the config in one device and upload later to others without any issue.
I have resolved the issue by myself.
Thanks, you been very helpful.
