GrooveA 52 - Health status
Hi, does anyone know if the health status on Groove A-52HPn r2 works ?
Becouse it shows voltage 32.7V and included power adapter is 24V
And temperature 91 C, which also doesn’t feel right to me.
Maybe is a RouterOS bug, what version are you using?
Regards.
Hi, version is 6.49.15
Check voltage with a multimeter. If values not match, open a ticket on MikroTik Support page.
Regards.
Uptime seems fine, there are no restarts. I already have it mounted on place, you know, “if it works don’t touch it” :smiley:
Checked: Voltage from power supply match
