GrooveA52ac - 2.4GHz and 5GHz at the same time?
Can a single GrooveA52ac offer wifi on both 2.4GHz and 5GHz at the same time when set up in WISP AP mode? Or would I need to two separate devices to do this?
Groove has single dual-band radio, so it can only operate in one frequency at any time. If you need dual connectiviry, then you have to use true dual-radio device (any other Mikrotik with support for both 2.4GHz and 5GHz) or two devices.
Thanks! I should have checked that before purchasing it, really!
