Hello all,
How would you ground (for example) a SXT LTE, where you have the GND / Earth connection, but there is no space for an 1 AWG wire to connect?
Hello all,
See this video:
https://www.youtube.com/watch?v=-KNo1B7K-YY
Sorry for bumping up this topic.
What I want to know is the correct diameter (d2 (mm)) to be used for ground cables in SXT CPE like this one.
Thanks.
This Mikrotik video shows grounding of SXT devices -
https://youtu.be/-KNo1B7K-YY
A short ground cable back to the main support structure.
I have seen that video. The question is what is the size of the ring terminal that the short ground cable uses.
About 3-4 mm hole size. the screw is M3.
Use one caliber to read the diameter of the screw,
done.
Remember to NOT use ground on this cases:
unshielded ethernet cable (UTP)
is useless, you must protect first the cableā¦
Device powered with galvanic separation
device not on pole or not on high point
