Group key timeout - Disconnected
Hi Everyone,
Recently, I bought a couple of cAP ac and deployed CAPsMan on my router. But I often encounter the WiFi drop out on my iPhone and laptop. I checked the log and it shows " group key timeout".
Once WiFi dropped out, sometiems, my iphone somehow doesn’t automatically re-connect and will use LTE instead, until manually re-connect it. Sometimes, it re-connect to the AP immediately.
Anyone else had same issues ? And how to solve it ?
Thank you!
I have the same problem.
Under 6.42.2 or 6.43.X I sometimes can’t even reconnect any more with any of the devices.
Under Firmware 6.41.X or 6.40.8 I still get the timeouts, but at least I can reconnect.
Submitted a file to the support. Gonna keep you updated.
Would be cool to just use one thread for the same issue, so people rather notice, there is something wrong.
http://forum.mikrotik.com/t/hap-ac-2-group-key-exchange-timeout-no-reconnect-possible/119697/1
What firmware are you running tho?
6.42.2 now, the previous version I had same issue.
Please keep me posted if you get any reply from mikrotik support. Thank you !
@Kerbia, any update from the support team at MikroTik ?
I have the same problem with Capsman + cAP ac devices. The Capsman manager runs on an RB1100AHx4 dude edition. I have tried already 6.42.7, 6.43.2, 6.43.4 ROS versions, but the problem still exists. Do you have any solution or workaround, that can eliminate or at least decrease this annoying phenomenon?
