Group name for the terminal?
When I insert a user’s User manager through the terminal, has the option of the group name in the User will be.
Anyone know how to put the terminal or just have to put the web?
Use version 5.0 rc4.
If you mean the “Group” in User Manager web interface, that is “group-name” in the CLI (terminal). If you are in the hotspot setup, that is “/ip hotspot user profile”.
The group you enter must be in the “/ip hotspot user profile” or you will get a “configuration error” on the hotspot login page.
/tool user-manager user
add subscriber=admin name=test password=password group-name=default
In version 4.xx works well, but in the version 5.xx group-name will not appear on the terminal.
