I am setting up and proforming upgrades with the dude server problem is i have both mips and x86 and when you select a goup and select upgrade it shows 2 2.9.27 pakages with no way to tell between them is this something that will be fixed?? i ended up deleting the 2.9.27 x86 so i was sure not to send wrong os to a box and i manualy did the x86 systems
any ideas??
thanks, we will check asap
