sir,
it is possible to use grove 5Hn as access-point (AP) and the CPE is the same unit also (grove 5Hn)?
BR
Roy R. Micabalo
sir,
BR
Roy R. Micabalo
If you have the A version (license level 4) then you can use it as AP. Otherwise (in case of L3) you can connect just one CPE.
