grovea 52hpn low reception signal
I have a 52hpn grovea and I want to configure it as a receiver, I’m doing tests comparing it with an awus036nh and the truth is very bad.
A router located 10 meters away with a wall in between gives me the result:
mikrotik antenna 6dbi: -86
awus036nh 5dbi antenna: -50
If I move the router a little further, mikrotik does not detect it.
That could be happening?
The only thing I did was reset and scan, is there any way to improve the signal?
Greetings, thank you.
