gsm, error allowed number does not match with: ???
I am trying to receive sms with RBSXTR v6.45.3
Sometimes smses are comming to inbox, sometimes not and in logs I can see following error:
gsm,error allowed number does not match with: +4853246xxxx
gsm,error allowed number does not match with: +4853889xxxx
gsm,error allowed number does not match with: +4857097xxxx
gsm,error allowed number does not match with: +4853919xxxx
gsm,error allowed number does not match with: +4872886xxxx
I didn’t set anything in “allowed-number:” field. It should allow all numbers by default as I understand…
after print it, it is showing some comas:
> tool sms print
           status: running
  receive-enabled: yes
             port: lte1
          channel: 0
           secret:
   allowed-number: ,,,,
       auto-erase: no
          sim-pin:
        last-ussd:
How to solve it to receive all sms’es
I had the same issue
I send sms’s to my SXT to run scripts, this changed in 6.43/6.45, I had to add my number to the ‘allowed-number’
After setting my number in the ‘allowed-number’ section, I could not see my number there, I am guessing this is for security reasons
It works very randomly.. sms’es from many number are comming to inbox, from some another numbers are not coming :frowning:
My goal is to know where what numbers I have in multiple devices. So I need to receive smses from all numbers.
Then by api I am logging to one RBSXTR that is receiving all smses and exporting all data from there to excel.
Unfortunatelly with this error all my approach is failure.
@Mikrotik please comment what is the logic behind it. Is it an error and you will fix it? or it is a feature :smiley:
I have same problem.
Had the same error after updating to 6.45.3
Tried to solve this with setting allowed number and deleting it via webfig and winbox with no luck.
But with terminal on 6.45.6 got it working again:
/tool sms set receive-enabled=no
/tool sms set allowed-number=+xxxxxxxxx
/tool sms set allowed-number=" "
/tool sms set receive-enabled=yes
thanks!
running 6.47.1 i had the same issue and was struggling in winbox to fix it.
via terminal with the commands i could get it to work again.
