GSM modem to send sms when highsight down?
Hi guys
Is it possible to setup a script or something which will monitor the network and send an sms to the technicians if a highsight goes down? Will the dude help?
thanks
use netwatch with sms send
http://wiki.mikrotik.com/wiki/Monitoring_Network_thru_SMS_Alerts
Thanks for that..
how can I modify the script to check wait for 5 ping losses instead if 1. Coz every now and then there is a bit of packet loss and I do not want to receive an sms just because of that
I’m curios of that. I’m sick of false alarm. 5-20 timed-out pings will be good.
did this a while back with dude notifications, first sending sms via email ( mailto: 5551234567@sms.att.net), which is an old standard email to sms interface system that most every reputable cell provider has.
later realized that if my dude box lost inet, emails would never get out. now using a gsm gateway and having dude execute a .bat that notifies us via the gsm gateway, so now notifications are completely independent of our network.
bellis…could you explain how your .bat file works? sounds very interesting
thanks
In dude, create a new notification. Select execute locally, or server, depending on your deployment.
In the command box, insert
sms.bat [Device.Name] [Device.AddressesCommaList] [Device.NotesColumn]
Make sure you chose what events you want to trigger this notification and when you want it run in the schedule and advanced tabs
create a .bat file containing
_“C:\Program Files\GnuWin32\bin\wget” -q --delete-after --post-data “bMobile=1&DEST=5551234567&HEXTEXT=%1 %2 is not responding to ping. %3.&Send=Send Now” http://192.168.1.1/smsSendNow.cgi
ping http://www.google.com -n 10
“C:\Program Files\GnuWin32\bin\wget” -q --delete-after --post-data “bMobile=1&DEST=5551234567&HEXTEXT=%1 %2 is not responding to ping. %3.&Send=Send Now” http://192.168.1.1/smsSendNow.cgi_
ensure you place your phone numbers in place of 5551234567, and set the 192.x.x.x to the ip of your gsm gateway
this should sms both devices. if you only want one person to receive an sms, remove ping http://www.google.com and everything after. if you need more than 2 phones messaged, add ping http://www.google.com and the cmd line for each additional number. the ping n-10 is simply to delay the sending of each message, as a gsm gateway can only send one message at a time.
this is exploiting a backdoor of our particular gsmn gateway, not sure if it will work on all, but it’s simple enough and definitely worth a try
also, don’t forget that your carrier’s standard text messaging rates apply. we all have at&t phones, and our gsm gateway has a at&t sim card, so it all falls under our unlimited mobile to mobile messaging
Thanks bellis for that…Will definetly give it a try soon
Hi -headstrong-
I use net Netwhatch to send sms when highsight is down or up, to do this set your host IP Address and intervals to 00:05:00 , timeout to 5000
Add this to Down section:
:log info “"
:log info "
— High sight One Down — "
:log info "
:local phonenumber { “+27821234567”; “+27828901234”; “+27847871234”; }
:local message “— High sight One Down —”
:foreach r in=$phonenumber do={
:put ("Sending SMS to " [:tostr $r])
:log info (“Sending SMS to $r”)
/tool sms send usb3 [:tostr $r] message=[:tostr $message]
Sir what if ISP has high ping and/or slow internet connection and not totally down. how to send also notification via sms sir?
